We've got a vertical turbine pump 4 stages 3 primary and 1 inducer. The pump is tested and 50 ft low in head....we've checked the wear rings, there's no slip in the impellers, we don't expect it to be hydraulics because efficiency is fine. Impeller diameter is normal.
Any suggestions????
Any suggestions????
