I have a centrifugal pump that is causing a lot of vibration and knocking in the adjacent piping. The pump draws ambient water from a tank, sends it through a weir-type diaphragm valve (wide open) and then through a UV "exchanger". The water leaves this area and goes out to process branches which consume the water. There is a bypass valve out in the system that maintains a differential and send unused water back to the tank. The tank also has a makeup valve that maintains a level.
The pump has at least 10' of static water head in the tank, so I should be fine for NPSH. If you listen closely to the video, you can hear knocking that sounds like I am pumping marbles. The manufacturer has apparently ruled out cavitation (not sure how, other than impeller looks good).
I am wrong with some of my pipe size comments on the video. I got interrupted and didn't have a chance to take another one. The connection on the bottom of the tank is 3". Suction pipe increases to 4", which is the suction connection size. Pump discharge is 2-1/2", and pipe expands to 3". Wier valve is 3". I am not familiar with the UV device, but its nameplate says that it is rated for 1000 GPM. I am told that the system pumps around 200 GPM. I am trying to get a pump curve. They run the pump around 75% on the drive. If they crank it up, the vibration gets crazy to the point where they are breaking the UV lamps.
There are no flex connections where the piping connects to the pump. I think this would eliminate the vibration that I can feel when touching the pipe. But, what about the knocking? That seems worse than the vibration. Any thoughts?
