Daren Samy
There are two identical PD (gear) pumps installed. Both feed lube oil to boiler feed water pump in stand by condition. It is interesting to note that discharge pressures (pressure guage installed before check valve) on both pumps before check valve are same one they are taken independently in service. Both pumps discharge pipings combine to form a header. There is pressure gauge in the header. When pump A is run individually, header pressure is 0.025MPa where as when Pump B is run individually, header pressure is 0.023Mpa (decrease of 0.02Mpa) is observed. Which thing causes decrease in flow ? There are only two items involved before common header. Pump B check valve and discharge valve . Which thing can be faulty Check Valve and Discharge valve ? If check valve is not properly seated and it restricts flow. Can it cause decrease in header pressure ?
Daren!
Daren!
