I have a 16 m deep 4" well beside my house that will be used for energy source for house warming with heat pump. Usual way to do it is to use a submersible well pump in the bottom of the well. I also have a second well that is used to return water after it was cooled, but this one is only 3 m deep and is used to drain water back to underground. Level of water in first well is around 3 m below surface and in the second one around 2 m below surface. Second one also gets higher when pumping water from the first one, because the water drains slower to ground.
My question is if I can use a pump in house and above ground level if I have a vertical check valve in the start of the water pipe in the first well and the pipe end outlet in the second well is always sumberged under water? Pump should suck water for about 1 m height (changes a bit during the year and with use), everything else are pressure losses in the system. I would like to do this, because the pump in house will be easier accessible and easier to service. What kind of pump would be appropriate?
