MIL-HDBK-5 allowable tables gives you the strength of fastener/material combinations.
the value is the lowest of the following failures modes:
-fastener shear (shear failure of fastener, based on Fsu_fastener)
-bearing (local yielding of adjacent structure, based on Fbrg or Fbru)
-shear-out (shear failure of adjacent structure, based on Fsu_sheet)
-Tension (tension failure of adjacent structure, based on Ftu)
Analysis is based on the material minimum or A-basis (ref Mil-HDBK-5) tensile yield strength and the thread min tinsile stress area (formua in Fed-STD-H28/2A table II.B.1 ), or the minimum shank ccross sectional area, whichever is least.
