PUMPDESIGNER
Would like input on experiences with published pump performance data. Tell me what your experience is good or bad. Specifically, do you see a trend of increasing variation or decreasing variation from published data?
REASON - We believe there has been a sudden rise in the last 2 years of variations that even surprise the manufacturers. In one instance the manufacturer admitted that they changed the casting process but not the shape of the impeller. Even they were not aware that the casting process had a dramatic affect on pump performance. In that instance the curve flattened out considerably, there was 18% less head at shut-off and 40% more power required at one performance point. In another instance pumps that we have been using for years have suddenly started to overload by about 10% when we always have impeller trims incapable of overloading the motor or using the service factor at every point on the pump curve.
We have documented our pumps for years and we know when something has changed because we use the same pumps over and over. We are also very careful to check site conditions for possible causes.
We believe that we see a trend where many manufacturers are not aware that manufacturing process changes are changing performance considerably.
Thank you. Richard Neff
Irrigation Craft
Irrigation Craft
