Akhilkp
- Jul 30, 2015
- 4
Hi all,
I would like to know more about PT flat slab construction steps / sequences .
As per the received method statement from contractor , following are the steps
1.Slab pouring with rebar and tendons as designed.
2.Initial stressing (25% of total stressing) when concrete reaches 15 Mpa ( approximately after 24 hours of pouring)
3.Final stressing (reaming 75% ),when concrete attain 30Mpa ( approximately after 3-4 days)
4.Cutting of strands
5.Grouting of tendons( bonded PT)
6.Removal of slab shuttering and reproping.
This is a 50Mpa grade concrete PT suspended flat slab designed as per ACI codes .
I have the following questions to asks:
1. Any problem if delays the initial stressing ( after 48hours ) ?
2. Has the initial stressing and final stressing any effect on shrinkage crack control ?
3. Any problem if delays the final stressing ?
4. Can we start de-shuttering just after the final stressing ( concrete reached only 70% of the design strength ) ?
Any help and comments really appreciated.
