The device is designed to trip the breaker via its trip coil or undervoltage coil. If the NGR goes out of spec, the device's internal relays change state, closing or interrupting the circuit to the trip or u/v coil respectively, and the breaker opens its main contacts. Often the devices are paired with a contactor instead, and can then just interrupt the contactor's main coil.
