BulbTheBuilder
I am trying to wrap my head around PT design on two items. I am still new to prestressed design so these questions might sound basic.
1. The hyperstatic force from the PT-tendons helps in balancing the load thus reducing stresses due to moment. Resultant of the precompression force stress and the bending moment stress leading to lesser stress in the system. How come the PT doesn't "help" with punching shear? Now assuming if I balance say 100% of the self-weight of the slab I now have to deal with super-imposed dead and live load for my bending and deflection. Why can't I consider same for shear?
2. Do you consider live load reduction in a two-way flat plate and what are your views on them? I am thinking about considering live load reduction for flexural and unreduced live loads for my shear check just to be on the safer side. Let's assume I have a floor usage for computer use (100psf) and I reduced the load to 80psf, can the floor be used for the intended computer use? Can I count on the redistribution of forces, how does this play out on the field when the building has been constructed?
