I am being asked to stamp an existing design that includes PSV venting to atmosphere. Relief case is pool fire under the vessel, and hence causing boiling of flammable liquids in the vessel. Liquid Mr = 54, ie heavier than air (although maybe not if hot). I'm accustomed to having PSV outlet to connected to flare for these designs. Where no flare system is available, I've only previously dealt with systems containing light gases (eg hydrogen or natural gas) that will go up if the PSV opens. I see other Eng-tips threads that discuss fire-case venting of propane (also heavier than air, but lighter than our vapour) - it seems that there are plenty of propane systems venting to atmosphere for fire case.
What is typically acceptable, in terms of heavier vapours venting to atmosphere?
The PSV discharge is aimed horizontally, so any discharged vapours will travel across the skid building and may fall to grade on the far side. The system is not located in a hollow; ie any heavy vapours vented will eventually disperse and/or flow away from the skid. However I could envisage a fire scenario where the PSV burps and vents heavy flammable vapours onto firefighters below.
Are there any standards or codes I should be checking, other than area classification?
