Hi all!!
I have a question about Fire Case in a vessel full of liquid (HX, etc..) engulfed by fire using API 521 recommendations.
a) At the beggining the liquid will have a thermal expansion and the PSV will relieve liquid.
b) After that, an increase in temp will relieve vapors generated with some liquid.
c) Finally (some hours?), level in equipment will reduce and only vapours will leave the PSV.
My question is:
1/ Which scenario do you normally use to size the valve?
2/ Do you calculate all cases and compare? or do you normally consider a typical case, for example, take the worst case in terms of duty/latent heat and consider ALL as vapour in worst case.
I dont know if there is a normal procedure as good engineering practice and I would like to know your always interesting opinions.
JASR76
My question is:
JASR76
