electricpete
- May 4, 2001
- 16,774
An induction motor circle diagram is also known as Heyland circle or Osanna circle / diagram.
It is a relatively straightforward phasor diagram representing currents in the equivalent circuit, and quantities derived from those.
The semi-circle shape arises from a plot of the following vector quantity (*):
I2 = V / (j* X2 + R2/s)
Specifically, if we plot I2 in the complex plane while we vary s, the tip of I2 traces a semicircle. The range of s to trace out a full semi-circle would be 0 to infinity (only 0 to 1 generally relevant for our purposes).
I can verify numerically that the plot of I2 = V / (j* X2 + R2/s) in the complex plane is a semi-circle for any arbitrary values of R2 and X2 that I choose. But I can’t come up with a proof why that is so.
QUESTION: Can you prove mathematically why a plot of I2 = V / (j* X2 + R2/s) in the complex plane traces out a semi-circle as we vary s from 0 to infinity
(* aside: I am neglecting the magnetizing branch component and focusing only on rotor banch current to simplify the question for my purposes... obviously we have to add in the magnetizing branch component to get total stator current).
