For a 50kW 400V motor just buy an overload relay to suit the motor full-load current. Normally a Class 10 overload is fine. If it is a load with unusually severe starting conditions, and if the motor is designed to cope with it, then you might look at a Class 20 or even a Class 30 overload. I've never come across a Class 30 relay in real life, even on conveyor duty, but they exist in catalogues. Standard IEC motors simply won't survive a Class 30 start, it would have to be a 'special'.
