Need assistance in calculating how to size a relief valve on the water size of a sheel & tube heat exchanger for a sudden rupture of one of the pressurized tubes on a 3-stage compressor cooling system.
The internal pressure is 3000psig and the closed loop water pressure is 70 psig. A water relief valve is in the water line that opens at 150 psig. The compressor flow rate is 130 scfm so once the sudden surge is displaced there will no problem relieving the steady state flow. However, how can the sudden expansion rate be calculated. Which in turn can be used to calculate the rate at which the water will be pushed out of the way to see if the water relief valve can flow sufficiently to protect the shell.
Any references or ideas on how to attack this problem would be appreciated.
