Here's a situation that has me confused.
For Methane, I have a P vs T chart that shows a critical temperature of -166F, Pcrit = 668 psia.
Now - for room temperature, which is well above -166F, would methane be at a higher temp using the PV=ZmRT?
In reality, methane is pumped into pressure vessels and very hard to liquify - so at low pressures (several hundred psi) it just depends on how much the pump pressure is.
What am I missing here? Any help would be most appreciated.
Thanks.
Thanks.
