Jamaz17
Automotive
- Aug 20, 2004
- 131
Does anyone have a list and/or general rule of when you should use fasteners and what fasteners you should use together?
Ie: If you use a SHCS through a thru hole and put a nut on the other side do you need a flat washer on either side (bolt head or nut side)and do you need a lock washer on either side? This is just one of many examples.
Or is there a rule of what washers, fasteners, nuts that you should not use together because it is ineffective or bad design practice?
