This is pretty basic, but what is the recommended procedure for creating the parts in an assembly?
From what I can see, it looks like there are two approaches:
1. Create a "base" part, drag that into a new assembly, and then use the "Create Part In-Place" command to create the others.
2. Create each part separately (where each is designed and sized so it will fit properly with mating parts) and then dragging each into the assembly, fitting them as I go.
With (1) I can use existing parts to create (include) profiles for use in creating mating parts, which will better ensure that parts fits properly. With (2) I have to know what the mating parts look like (in both shape and dimension) so I can create a part that will fit. But I can reuse this part in other assemblies, if wanted. An "in-place" part appears to be specific to the assembly in which it was created.
Any suggestions? Thanks for the help. -Pat
