Brandy7,
Your specification would depend massively on what you are trying to accomplish. I agree with the above comments about angle dimensions being basic. Plus/minus dimensions get increasingly meaningless as the geometry get complex. You need to define datums carefully, and think through your GD&T specifciations.
[ul]
[li]Is the surface at the end of your shaft a critical feature, suitable as a datum, or should your pin be located 15[°] from the shaft OD?[/li]
[li]Is the angle critical, or is it the location of the pin or the outline of the pin?[/li]
[li]Are there any other orienting features on your shaft?[/li]
[li]How are you going to inspect it?[/li]
[/ul]
JHG
