Hi Ringman,
Y14.5M-1994, Section 4.4.2 Parts With Cylindrical Datum Features; "A cylindrical datum feature is always associated with two theoretical planes intersecting at right angles on the datum axis. The datum of a cylindrical surface is the axis of the true geometric counterpart of the datum feature..., and simulated by the axis of a cylinder in the processing equipment. This axis serves as the origin of measurement from which other features of the aprt are located." See also Fig. 4-5.
The standard outlines basic fundamentals or principles, but unfortunately doesn't provide much guidance on some of the more challenging real-world situations that we all encounter. Instead, they expect us to make logical extensions and correlations of the principles to new situations. A conical surface used as a Datum Feature is one of these situations.
By extension, the surface of a cone has an axis which is the datum (the result of an infinite number of center points of opposed points around the cross-sections along the length of the cone). Similarly, by extension the axis of the cone generates two mutually perpendicular datum planes which are the origin of measurements in 2 directions away from the axis of the cone.
The next part is the real challenge, and I came to understand it as the result of discussion and debates with several of the people who actually write the standard. Whereas the cylindrical surface is always parallel (or equidistant if you prefer) to the axis of the cylinder, the surface of a cone converges at the cone's apex. This point is effectively a limit or origin of the axis, and therefore the origin of measurement along the axis (the axis is, as always, theoretical and extends infinitely in both directions beyond the apex). Added to this, measurements originate at datum planes. By combining the two, the apex of a conical surface therefore generates a datum plane which is mutually perpendicular to the two datum planes generated by the datum axis. Furthermore, this third datum plane (not tertiary, but third) is the origin for measurements along the axis.
It's a lot to take in, and not easily understood. For that reason, many senior GD&T experts will go to extreme lengths to avoid using a cone as a datum feature; some people add non-functional features such as cylindrical and planar surfaces to bypass the situation.
If the link isn't even launching your internet browser, try copying the address it into your browser. If it's launching the browser but not going beyond that, you may need to accept Mooload.com's cookie. Once you get into the site, under the bolded DOWNLOAD LINK is a hyperlink "Click Here To Download". If there's still no luck, post again.
Hope I've been able to help.
Jim
Jim Sykes, P.Eng, GDTP-S
Profile Services
CAD-Documentation-GD&T-Product Development
