Hi All,
Attached a bushing drawing created as per ISO GPS standards. Many Dimensions are removed intensionally to obay comaney IP policy.
Assembly works this way, the M30 Stay bolts will passthrough the center hole of the bushing and engages with the thread.
Drawing callouts for a coaxiality tolerance for M30 threads, The thread axis should be coaxial upto a projected length of 230mm in the shown dirction. The coaxiality tolerance is 0.1 mm.
Whether the stated tolarenace is difficult to acheive? How to make sure while manufacturing, the thread concentricity is maintained for such a long projected height. does it demands for expensive tooling.
I beleive it can be verified only with the help of CMM.
