Projected Area of a part? 2
jabbermacy
Automotive
CN
What's the easiest way to get the projected area of a part in die view? I'm working in IDEAS now, but would like to know if it's still a manual procedure in NX or what...
Thanks.
OK, this works in NX 3 and 4, but I just discovered that it's broken in NX 5 (I've opened a PR).
You first need to do a little pre-setup. Take you model and rotate it around until you're looking normal to the desired 'projected area' (make sure that you have turned OFF perspective display). Now go to Format -> WCS -> Orient... and select the 'CSYS of Current View' option.
Next go into Preferences -> Visualization... and select the Visual tab and then the tab labeled 'Edge Display' and then change the Hidden Edges option to 'Invisible' and hit OK.
Now go to Insert -> Curve from Bodies -> Extract... and select the 'Shadow Outline' button. As soon as you select the button the function executes and usually you will not see anything change on the screen, but if you now Hide (Blank) the solid body you will see a 'Shadow Outline' of the body. Note that these are 3D curves extracted from the solid, based on the visisble 'outer profile' or 'Shadow Outline' of the solid.
The last step if you're looking for a 2D representation of this 'Shadow Outline' is to go to Insert -> Curve from Curves -> Project... and select the Curves and and then for the plane of the projection, under 'Plane Method' select 'Set to XY Plane' and then hit OK.
You now have the 2D 'projected area' of your original model.
John R. Baker, P.E.
Product 'Evangelist'
NX Product Line
SIEMENS PLM Software Inc.
Cypress, CA
If you have problems, (because of NX-5) perhaps you could do it another way.
Insert -> Curve from Bodies -> Extract... and select the 'Isocline' button, Set the vector to Z and the angle to "0" zero degrees and select the body using "All in Body" as your target.
Follow John's instructions to project to the plane of the WCSYS, and you're done.
You asked for the best way though and Shadow Outline is it.
Hudson
BTW, the Shadow Outline works in NX 5.0.0 and NX 5.0.1. We've determined that the problem was only in NX 5.0.2, which has not yet been released (note that this bug in NX 5.0.2 will have to be taken care in an MP, Mainteance Patch, as we have missed the deadline for the NX 5.0.2.2 Maintenance Release, which goes out in about a week).
John R. Baker, P.E.
NX Product Line
Cypress, CA
THANKS!! Seems similar to the silhouette curve in IDEAS!
