Programming NX
RuudvdBrand
Computer
Aug 6, 2012
34
Does anybody know what kind of programming language the ugii_env.dat file is?
I want to execute a batch file from the ugii_env.dat file.
Greats
Ruud
NX reads and interprets the options on startup, I don't think it is meant to execute batch files.
However, you can get NX to execute external commands at startup and/or other 'user exits'.
www.nxjournaling.com
What version of NX are you dealing with?
Explain what it is you want to accomplish with your bat file?
ugii_env.dat is a text file that stores the system settings and is read at system startup.
You can launch NX from a bat file and have it run a called bat file of your own to set variables before the NX start call.
You can launch NX and have it run a program after launching.
You can use the 'user_exits' to run custom code at various menus.
Lots of ways to run our own code with NX.
Ben Loosli
