Proe mechanica not run
  • Thread starter Thread starter sudhir.patyal
  • Start date Start date
S
sudhir.patyal
Guest
Dear all
i m running the proe mechanica and done all steps but when start the run button two alert msg display and then run complet. afterwards start thr calculation step it shows the msg the calculation not start.???????????
Whats the problem pls solve my problem help me..........
Can you attach a screen shot or the .rpt file?
We have similar problem. When you try to run study Mechanica gives you an error message "Cannot start design study...". Our ProE is WF4 M080 (OS 32-bit XP Prof. + SP3). M070 runs well. Next I will test it with 64-bit enviroment.
29.07.2009
Problem is solved, for some reason not all files were installed for the Mechanica. I uploaded new packages from PTC site reinstall and now it works.
Edited by: motskari
