producer of tubing stainless steel
jos42
Automotive
May 10, 2004
4
is there anybody who can tell who is de producer of the stainless steel tubing 1.4509, tubing must be aviabel for bending.
i am looking for the diamension
ø 45 x 1.8 in a year 15.000 meter, pro delivery 3.000 meter
ø 30 x 1.8 in a year 30.000 meter, pro delivery 3.000 meter
ø 35 x 1.5 in a year 120.000 meter, pro delivery 12.000 meter
You need to specify the grade of steel because the companies which produce ferritic exhaust system tubing usually specialize in it and don't make the austenitic tubing.
Jos42,
Try searching Thomas Register or similar industrial supply index. You should also take care to specify in greater detail what you are looking for (i.e. units (mm assumed) and performance specifications).
Best regards,
Matthew Ian Loew
"I don't grow up. In me is the small child of my early days" -- M.C. Escher
