Proctor test
killswitchengage
Geotechnical
DZ
Hi
why is it necessary to use 5 points in the proctor test , if 3 points can help you to find the optimum quiet easily
In some soil types, there is a "double peak" in the curve, with one peak lower than the "real" one.
Four points should be adequate to define a curve.
With non-cohesive soils, it's often better to have more than 4. Proctor tests on these soils can be a bit erratic.
Dik
FDOT now requires 5 points for LBR
for cohesive and non-cohesive? Clays in our environs give very consistent values.
Dik
Agree with dik that some soils require 5 points. I deal with coastal plains soils in Florida and sometimes it is necessary.
jmcc...correct for LBR....a special test relevant to Florida.
So kind of you to answer
can someone provide me with an example with a double curve phenomena and which material is it
Ok so Lee and Suedkamp 1972 studied the forms of proctor curve and they relate some of them to the liquid limit of the soil
