I recently purchased a 240 gallon pressure vessel that I plan to utilize as a compressed air storage receiver in my shop. The vessel was manufactured in 2002 and is rated for 200 PSI MAWP @ 400 degrees F. The vessel is designed to be installed vertically. I plan to operate this vessel at 175 psig. I would like to hydrotest this vessel to ensure that it can be operated safely. I am doing this solely for peace of mind and therefore I do not need any type of certification. A picture of the vessel nameplate is uploaded.
I am planning to leave the vessel on the trailer horizontally, fill it all of the way up with water using a garden hose, pressure up to 30 PSI using a hydrostatic test pump, hold the pressure for 5 minutes, pressure up to 300 PSI (1.5 x MAWP) using a hydrostatic test pump, hold the pressure for 5 minutes, bleed off pressure, drain, set in place, and then put into service.
Do you have any recommendations regarding my procedure? Is there anything that I am forgetting?
I have no experience hydrostatically testing pressure vessels. I own a 10,000 psi hydrostatic test pump that I use for pressure testing oilfield equipment that I will be utilizing for this.
Vessel Nameplate
Vessel Nameplate
