chooga4eva
Bioengineer
Attached is a video of my model as it is impacted by a rigid part. This is a bone impacted by an analytical rigid part.
There are three problems:
the analytical rigid part in the part module appears as a rectangle (which is how it is desired) however in the simulation (visualization module) it appears as a thin line (please watch the video). I would like to keep the original shape of this part...but how? and why does it change in the first place?
The second problem:
the rigid part is not making any contact with the bone, it just seems as if it is exerting a force toward the bone that causes the bone to deform but that is it. There is no actual contact! I applied a surface to surface contact, with a kinematic contact method, assuming it is frictionless.
Third problem:
the bone is bending too much! this is erraneous. I need to define a point at which elasticity of the bone no longer holds (I have defined elastic properties to the bone). How can i do this?
I will be immensely grateful for any help!
attached is the simulation video please check it out!!
