Problems running Pro/E 2001 Student Edition on Win XP Pro
  • Thread starter Thread starter RR
  • Start date Start date
R
RR
Guest
Sir,
I've installed Pro/Engineer 2001 Student Edition but I can't open the program itself. I get the error message:
xtop.exe - Application error
The instruction on 0x00000000 refers to memory on 0x00000000. The read- or write process on the memory has failed.
Does anybody know how I can solve this problem?
Thanks in advance,
RR
See if this works........
Start > Run > msconfig
General Tab > Selective Start Up - Uncheck > Load Start-up items
Services Tab > Check - Hide all Microsoft Services > Disable all
Restart Computer
Load CD.......Hope this works
Once installed, Revert all the previous settings
Restart again.
st6435,
Unfortunately this solution didn't work, but thanks anyway for your help.
RR
RR,
Were you able to fix the problem a different way? I am having the same trouble?
Denny
I had a similar problem, and found that the CD was required to be removed from the CDROM drive (unlike 2001) in order to run.
I had errors with Pro/E Student & solved these by allowing Pro/E to access the internet during startup...
I think this is related to the TCP/IP usage & I'm not sure how to stop this happening.
RR-
I had a problem with 2000i^2 SE installing when my virus protection software was enabled. Perhaps your installation was affected and perhaps 2000i^2 and 2001 share the same problem.
