I recently started using femap 11.1 and I've been having a problem for the past two weeks that I can't solve.
I have a simple assembly of two parts that I exported as a parasolid ( .x_t) from solidworks.
When I run the FEA static analysis in solidworks simulation , it works with no errors.
When I open the parasolid assembly in femap , and when I run the analysis I get a fatal error 9031 (ERRPH1) .
I tried reducing the size of the mesh, I ended up with more errors.
I tried to check element quality ,I ended up with missing surfaces.
Only one of the two parts is causing the problem,is there a way or program to fix the part?It's really frustrating.
Any ideas why the same assembly works on solidworks simulation but not on femap ?
Thank you very much.
