Problem with Amada 3015 Laserbeam won't work
John WV
Computer
Feb 4, 2022
Saudações pessoal, estou com problemas na hora do corte laser da AMADA 3015
O laser para corte não funciona, simplesmente não liga e não corta
o gás funciona mas o laser simplesmente não aparece, alguém ja teve esse problema sabe oque pode ser ?
ja ligamos e desligamos a máquina e não adiantou.
Greetings everyone, I'm having problems with the laser cutting on the AMADA 3015
The laser for cutting does not work, it simply does not turn on and does not cut.
The gas works fine but the laser simply doesn't show up, does anyone who has had this problem know what it can be?
We already turned the machine on and off and it didn't work.
Which model 3015 - It appears Amada made a lot of them with that number in the name. When was it made?
if machine starts normally but no beam comes out of the nozzle it is usually a blown mirror or lense not allowing the beam to travel
Thank you all for the replies but we already have identified what is the problem.
Mirrors are damaged and we had a problem with gas leak also causing gas contamination
