Hi everyone,
I have a 2 layer board with one GSM and one GPS module. The operation voltage is 3.7V and 3.3V for the GSM and GPS. Is there a problem for the two voltages to be on the same board?
The tracks are not very close to each other(4 cm at least) and the board thickness is 0.5mm. If the tracks are on different sides is it still a problem? Is the difference of the two voltages significant enough to cause crosstalk?
Thanks in advance!
Thanks in advance!
