Probably dumb/newbie Hole Wizard question
Chale4
Very new SW2011 user, forgive me ahead of time. In using Hole Wizard to create a simple blind drilled hole (i.e. 118 deg end), I am finding it very "unnatural" for the Depth call-out to be stuck with having to be "the depth to the end of the hole diameter", as opposed to, "the depth to the end of the drill bit", i.e., the tip of the 118deg end of the hole! This is, to me, "what counts", when assuring one doesn't break thru, etc. Is there some way to control this, other than to haul out the calculator to do the trig for that part of the depth of the hole, and manually correct the Depth value entered in Hole Wizard, accordingly?? Thanks--chale4, Lafayette CO
Standards are standards. The depth of a drilled hole is measured to the depth of the full diameter, not the tip, so the Hole Wizard is doing the right thing. If you want to do something different you certainly can, but you'll have to modify your approach.
Notice that the hole wizard creates two sketches, one for the revolved cut profile and the other for the location. You could edit the revolved cut sketch to control the depth to the tip, or you could use the special hole feature where you can control the complete profile.
- - -Updraft
Chale4,
Upddraft is correct, and SolidWorks does provide the correct dimensional scheme. If you don't want to break through, you can simply use a note added to your callout like "DO NOT BREAK THRU".
Matt Lorono, CSWP
Product Definition Specialist, DS SolidWorks Corp
Personal sites:
Lorono's SolidWorks Resources & SolidWorks Legion
'you can simply use a note added to your callout like "DO NOT BREAK THRU"'
huh? Why even model the hole if you're going to do something like that? That's just throwing the whole thing back onto the machinist/operator. If you're going to do that, heck, just mark the center and put a callout "____ Dia HOLE TO AT LEAST ____ DEPTH. DO NOT BREAK THRU".
