Depending on the amount of text, you can simply select Modify Text (Line or Full) and when in text editor, just copy or save as (.txt) and export to a word processor program.
The easiest method will be to stop using Pro/Table & instead use Notepad as your default editor. From there, you can save the file as .txt straight-way. Shacheendra Sharma
