I am using Pro/E 2000i2. I'm not sure how, but my Pro/Table wont load any more. My Family Table Editor and all other editors seem to work fine. When I try to modify a hole pattern though, nothing happens. Anybody dealt with this before
It is not necessarily anything to do with the pattern table. For example. If you do a save as on an assembly, Pro/E will ask you if you want to copy the parts also. If you select any of the parts, it pops open Pro/Table dialog so that you can enter new part names. This is how I have nailed it down to Pro/Table.
No I didn't just install from an older version, but that is a very valid question given PTC's history. This feature worked and just recently quit working.
This might be something as simple as a corrupt protable executable.
Short of reloading Proe you might try overwriting the executable in the bin directory with an older backup.
Also you might try running it from the bin directory.
If it works it will tell you whether it's the executable file or something else not allowing it to run: Proe setting or some other newly installed software.
procadman2
Proe Design & Admin
NASA Contractor
"You can't build a reputation on something you haven't done."
H Ford
