MuzamilEETC
I have an assembly of 3 components (End wall, End plate, and Closure Key) in Pro/mechanica. All the Constraints, Material properties, connections & some springs as Idealizations are assigned as per requirement. A pressure of 2000Psi is acting on the End wall and End plate as shown in attachment. When I check the result there was no displacement in the closure key. I need to calculate what is the strength required for the bolts on the closure key, or need to increase the no of holes on the closure key to withstand the opposite pressure.
