- Thread starter
- #21
J
joebarnes
Guest
I did download, install and configure the DDM trial today. In less then three hours I was creating, saving to, searching and retrieving files from DDM. I do think it would take a few good weeks of working with it to more fully understand the inner workings and behavior before being able properly configure it. Intralink 8.0 took me about 2 weeks and 5 trys to get to the same point and I was looking at least a few good months before being able to properly configure it.
When using Intralink 3.4 with Pro/ENGINEER you effectively have 3 distinct working areas: CommonSpace, WorkSpace and In-Session. DDM seems to only have Workbench and In-session, with the workbench being part of the common vault. Is this an accurate depiction?
Can the Common vault be browsed like a standard file system?
Is there some sort of folder structure in the common vault?
When objects are removed from the workbench or project folders where do they go?
Can model attributes be automatically passed to DDM when saving a model file?
We have some toolkit applications that will retrieve specified models. If the model is not in the current workspace it is automatically retrieved from the commonspace with no additional handling. Same as if you clicked File >open and typed in the full model name.
Would toolkit apps like this work with DDM?
How can a model be replaced in DDM? One possible way with Intralink is to create a new model in session, rename in-session to an existing name that is in the workspace and then save over top. In DDM I get a message that the object exists and I cannot overwrite.
Can this be overridden?
What would the recommended path or procedure be to migrate objects from Pro/INTALINK to TDM and keep everything intact? 200K+ objects
If you start up DDM Pro with Pro/ENGINEER and you start up DDM Office is that using 2 licenses or 1?
