Print Report - Saved Settings
TerryScan
I have set up saved Print Report settings a number of times (about 6)and frequently lose them.
From help:
Note that named report settings are stored in the Windows user settings, and not in the HydroCAD project file.
On one hand this is a good thing so that the settings could be used on multiple files, however, I lost them when i have NOT unchecked "keep settings". I believe it just happened when we had an internet disruption.
Perhaps it would be better if the settings could just be saved to a separate file.
Thank you,
Terry Scanlon
Like all user preferences, the saved reports are stored in the registry only when you close HydroCAD. If the program is interrupted without doing a normal exit, settings are not saved.
Also be sure you are running HydroCAD 10.2-4b or later. Earlier versions would loose ALL saved reports after an abnormal exit.
Peter Smart
HydroCAD Software
