Price of steel members per pound 2016
oengineer
Does anyone know where I can get information on the price of steel members per pound? I am looking for the most current value this year. Mainly for HSS Tube members.
Why not just contact local steel suppliers and ask for some prices on sizes similar to the ones you need? Should be able to get a rough price per pound that way with more accuracy than a rough country-wide estimate.
Professional and Structural Engineer (ME, NH, MA)
American Concrete Industries
@ TehMightyEngineer
Thank you.
Definitely go that route. It's actually extremely variable depending on location and time of year.
...and depends on what Asian manufacturers are "dumping" on the US market too.
Depends on the shape and whether it's a stock item or not, too. I've seen HSS be a lot more than wide flange per pound for similar grades of steel and sizes because they said it wasn't a commonly stocked shape for the local suppliers.
Delivery costs can also vary greatly. As TME said, check with a local supplier. Then, check with a large, regional supplier. The tonnage needed may also affect the price.
I used to estimate for a local steel fabricator. We purchased structural steel from out of state. Any "local" mid-size to large general contractors are either going to purchase their steel from the same steel corp distributor (if they have their own fab shop) or from the fabricator who will also purchase from the same.
Your typical "local" steel supplier, is going to also purchase from the same distributor and then add a mark-up to their price for smaller local construction companies and independent contractors.
My point is, most of your structural and miscellaneous (stair) steel is ultimately going to be purchased from the larger national monopolies. Therefore, by the time any job-site receives it, you will be paying a very comparable rate.
(On a side note, "Inginuity" also has apparent reasonable insight in that, whatever is not manufactured state-side, will be purchased overseas - that's another story...)
Even though you are more interested in HSS, here is a link to the latest May 4, 2016 price list (for "W" and similar shapes) from Nucor-Yamato:
15-20 years ago when i was with the fabricator, we were purchasing structural steel for +/- 0.25-0.32 / LB or 25.00-32.00 / CWT. Fabricated structural was then sold for +/- 0.50 / LB and miscellaneous for 0.75-1.00 / LB.
Based on the price list from the link above, it looks like your typical W-flange structural will be purchased at 0.35-0.44 / LB and then fabbed and sold at 0.60-0.70 / LB and miscellaneous for 0.90-1.20 / LB.
I realize you're inquiring about HSS, which will be even higher than wide-flange, so maybe "zcp" is in a reasonable range. Perhaps this may also be valuable for you and others.
Whether HSS, W or other shapes, both structural and miscellaneous can get higher depending on how much fabrication has to be done to it, i.e. drilled holes, miters, copes, shear tabs, siffeners, gussets, etc...
Keep in mind, when you get pricing from any local steel "supplier", you are only considering raw, un-fabbed product. If you contact a local steel "fabricator", they would give you a better estimate on the finished product.
Hope this helps.
I meant to give you these if they would be helpful:
Atlas Tube - Blytheville
5039 N. County Rd. 1015
Blytheville, AR 72315
Phone:870.838.2000
Fax:870.838.6630
sales@atlastube.com
One Chicago Tube Drive , Romeoville, IL 60446
Phone: (815) 834-2500
Fax: (815) 588-3958
I'm seeing $6-$10 per kg depending on the complexity and area, fabricated, coated and erected in Canada.
