Hello everybody. I am trying to analyse a bolted joint and i have defined pretension to the bolts. But i see that the pretension section shrinks and the bolt head has negative stresses even though the preload is a tensile load which i didnt understand why. I have defined pretension in step 1 using cload and in the second step i have applied the external load using cload,op=new and i have also used boundary,fixed in the second step. is this right or am i missing somethin? looking forward for your reply. Thanks.
Kota
