My understanding is that these guidelines are now covered by the PED(Pressure Equipment Directive).An extract from this is as attached.
On the same note the scope of API 510 are as follows(some extracts) :-
1.1.1 Coverage
This inspection code covers the in-service inspection, repair, alteration, and rerating activities for pressure vessels
and the pressure-relieving devices protecting these vessels. This inspection code applies to all hydrocarbon and
chemical process vessels that have been placed in service unless specifically excluded per 1.2.2; but it could also be
applied to process vessels in other industries at owner/user discretion. This includes:
a) vessels constructed in accordance with an applicable construction code [e.g. ASME Boiler and Pressure Vessel
Code (ASME Code)];
c) [highlight #FCE94F]vessels constructed and approved as jurisdictional special based upon jurisdiction acceptance of particular
design, fabrication, inspection, testing, and installation[/highlight];
With due quality requirements in place application of API 510 may be feasible, provided design, repair alteration program, personnel qualification to API 510 are in place. However acceptance of the AI would be mandatory.
Thanks.
Pradip Goswami,P.Eng.IWE
Welding & Metallurgical Specialist
Ontario,Canada.
ca.linkedin.com/pub/pradip-goswami/5/985/299
