Pressure Vessel Steel Plates for Sour Service
QW Tian
9
Dear Community
I wish to seek help from the Community regarding the SSC and HIC requirement in ISO 15156 for steel plates used for pressure vessels.
ISO 15156-2015 states the following requirement for pressure vessel steels:
"A.2 SSC-resistant carbon and low-alloy steels and the use of cast irons
A.2.2 Application to product forms
A.2.2.2 Pipe, plate, and fittings
Pressure vessel steels classified as P-No 1, Group 1 or 2, in Section IX of the ASME Boiler and Pressure Vessel Code are acceptable.
Products made from flat-rolled steels in contact with trace amounts of H2S [i.e. even if pH2S is below 0,3 kPa (0,05 psi)] can be susceptible to HIC/SWC damage."
So for SA516 Gr 60 and Gr 70 steel plates,
1) Is it correct to say that, since they belong to P-No 1, Group 1 and Group 2 respectively in ASME Section IX, these plates would inherently SSC-resistant and the only tests are hardness and HIC tests and not SSC-test ?
2) is there a need to perform any SSC-test and HIC-test for the welding qualifications ?
3) is there a need to perform any SSC-test and HIC-test for the production testing ? The need for such crack-resistant tests are silent in ASME VIII Div 1/2.
1) No - because it is down to the end user to decide. See the Warning ahead of Clause 1.
2) Possibly - dependent upon the end user's directive
3) See 1) and 2) above
Steve Jones
Corrosion Management Consultant
All answers are personal opinions only and are in no way connected with any employer.
Dear Steve
Thankyou for your response to my enquiry on Pressure Vessel Steel Plates for Sour Service.
I would appreciate very much if you could point to me the Clause 1 mentioned in your reply ?
I need to deal with a steel mill who insisted not to conduct SSC tests by complying to ISO 15156 A.2.2.2.
regards
QW Tian
Clause 1 is at the beginning of the document on page 1. It starts with the character 1, and is followed by the word "Scope." Above "1 Scope" is a paragraph, all in bold type, where the first word is "WARNING."
Hope that helps.
Steve Jones
