pressure-tight bearing?
biff44
I have a large steel pressure vessel at 100 PSIG with gases inside. Gas temeprature might be as high as 600 degrees F.
I need to pass a long ceramic rod, perhaps 1/2 inch diameter, through the side wall of the vessel. I am looking for a bearing that can hold the rod at the vessel wall, allow it to rotate, but be gas-tight. Rotation rate will be around 10 RPM.
Any suggestions?
Thanks for the help.
Rich
Maguffin Microwave wireless design consulting
The rod has to rotate, it seems a stirring shaft for me, and you need a gland type seal. But your rod has to be very smooth, otherwise you need mechanic seal, it is a stand product for pump and pretty expensive.
Contact your local Crane seal rep.
Let us know what solution works for you!
Good on ya,
Goober Dave
