stoppit
Chemical
- Nov 2, 2009
- 10
Hello
I hope someone can help me with this. It's a simple question but I'm not from a classical Chem. Eng. background so could do with a pointer. If you have a sealed tank of volume V and you fill it to some proportion x (0-1) at a rate Q L/min, how can I determine the final pressure in the tank as a function of time (or fill level)? It seems like it should be easy but I've not done this before and I don't know where to start. Can I take pV^n = constant and substitute the time-dependent vessel volume V(t) for the volume term?
The pressures are low by process engineering standards and the fluid is water based to let's assume compressibility is zero.
In an extension to this, if the contents are reacting and undergo a small volume change on reaction, how can I build this in to the calculation?
Many thanks.
Many thanks.
