Dear Mr.Molero
I made all from the start:
1) delete mesh and also projected imprint area ( for load definition)
2) remesh
3)New imprint for definition of loaded area
- geometry - curve-line-rectangle
-geometry-curve-from surface -project
4)model -load-on surface
- then I selected created area for load definition, set pressure value 0.02 MPa
5) analyze (static)
- And now again the same problem appeared- shows zero stress and deformation
Is it important to project rectangle curves before or after meshing the surface area of plate?
Actually I tried without rectangle imprint, I just put force on each node in loaded area. It worked but results were peculiar(too large deformation)
and this way It is more difficult I think, It would be easier with imprint area.
Thank you!
Best regards,
Martin
