Pressure loss pipe fittings during a laminary flow
Yobbo
85
I have got the following question. With turbulent flow fittings have got an almost constant loss factor. It can be found in the literature and internet. Now I am confronted with the question to calculate pressure loss over a fitting with laminary flow. I know that turbulent flow results in a quadratic function ( dP = K*1/2*rho*v^2 ). This goes for the piping itself and the fittings. With laminary flow though the relationship between pressure loss and flow velocity is linear. I assume that the fittings in this case will also behave as a linear resistance. Where can I find the bygoing constants?
I would just take f=64/Re, use Darcy-Wiesbach and call it a day.
SNORGY.
If you search here for the 2-K and 3-K methods by Hooper and Darby respectively you will find what you need. You are correct that while the K factors for fittings can be regarded as constant for turbulent flow with reasonable accuracy, the K factors are very different for laminar flow. However, the equivalent length values (i.e. Le/D) obtained for fittings in turbulent flow can be used for laminar flow. Using Le/D values will generally estimate slightly higher pressure drops than the 2-K and 3-K methods.
Katmar Software
Engineering & Risk Analysis Software
K factors of fittings in laminar flow usually take the form of a constant divided by the Reynolds number, i.e. K = A/NRe. The slower the flow the larger the K.
Good luck,
Latexman
L.S.,
Thank you for your swift reactions to my questions. I will dig in deeper along the suggestions being made.
