jimtheengineer10
A client owns a mobile home park (75 homes) that is having some pressure issues. We are in the process of designing an entire new system but they want to fix their existing pressure problems before winter hits.
There is an on-site well that feeds an approximate 630 gallon metal storage/contact tank. The tank then discharge through a 4" pipe through the floor out to the homes. They are having pressure issues so they keep pumping air into the storage/contact tank. I am proposing three new 119 gallon pressure tanks to be installed.
I have met with a couple contractors who install these systems quite a bit and am getting different opinions. One says the three new 119 gallon pressure tanks should be installed before the contact tank and the other says they should be installed after.
Should the pressure tanks be installed before or after the contact/pressure tank?
