MattNCSU03
I am working on 1200MWe turbine-generator (1 HP, 3 LP) set and evaluating the effects of going from full-arc to partial-arc steam admission. The unit has four control and stop valves governing steam admission to the HP. Looking at the drawing, I noticed that between SV1 and CV1 and SV4 and CV4 is are pressure transmitters that feed different control loops.
In full arc mode there should be the same steam flow and pressure drop through each valve so the PT would sense the same pressure but in full arc assuming CV1-3 are full open and CV4 is modulating, would the PT just upstream of CV4 see a different pressure than the PT upstream of CV1 because the changing steam flow through the CV or would both PTs still have the same pressure as the source?
[tt]
HP---CV1-PT1-SV1------\_____
HP---CV2-----SV2------/
HP---CV3-----SV3------\_____
HP---CV4-PT4-SV4------/
[/tt]
[tt]
[/tt]
