Pressure Drop Calculations for Double-walled Pipe
swilson3
CA
Hi all,
I am looking to (roughly) calculate pressure drops for ventilation air across the outer area of double walled fittings (elbows, straights). I can't seem to find any literature on how to best approximate this type of losses. ie a DN125 pipe inside the DN300 pipe where the ventilation air flows through the outer section of the pipe.
Thanks!
sw
how about only posting in one forum.
You probably will have to obtain this information from a manufacturer of double wall piping.
You need to do a search on this site and others for "flow in annular"
Then you find things like this....
It isn't a very common issue so there isn't much about, but the methods in the FAQ look pretty good to me.
