drax: It's rather surprising that your vessel hasn't exploded or that you haven't experienced incredible shock; 4,500 amps is enough current to give even the most jaded GE Nuclear engineer pause. At any rate assuming that the vessel was filled to the 2/3 level at atmospheric conditions your starting conditions should be as follows;
T1 = 68 deg F
P1 = 16.2 psia ; 14.7 + 1.5
v1 = 0.01608 cft/lbm; specific volume of the water
Assuming that you ran current for approximately one hour; I assume you have some type of heating element in there, the amount of heat energy given to the water would be;
Q = 3,320,000 Btu's or 972 KwHrs
Which is enough to raise the water temperature over 2,000 deg F. So conditions after one hour would be;
T2 = 2,128 deg F
P2 = 8,670 psia
v2 = 0.0241 cft/lbm
The pressure in the tank was extrapoted off the tables for superheated steam and it is assumed that all the water has become vapor. While I find your story rather improbable I was interested to find out what the results might be like and I hope that you find them of some assistance to you. However what I can't understand is why none of the replying engineers didn't mention to you that a: the 4,500 Amp current sounds very unrealistic and b: there should be a relief valve on your tank so that the pressure never goes much beyond say 30 psi. about what you find in your average car tire. So no it's not at all surprising that your tank "bulged". I wish you all the best of luck with your tank and if I can be of any further assistance to you feel free to drop me a line at dsigel@pacbell.net
Sincerely,
Dave Sigel, ME
