We have a 2 floors building and another 4 new floors are being constructed.
We would like to have a booster pump at the second floor.
The 7th floor is at the height of 24 meters. Here the hot water tank is being proposed.
We are evaluating the pump options.
The booster pump is planned to setup at 2nd floor.
First options to have top 4 floors through booster and the bottom floors through gravity.
The booster pump is 1.5 HP with 7500 LPH. Pressure is 2.2 - 3.6 Kg/ cm2
Second option is all floors are through booster with pressure 2.4 - 4.4 kg/ cm2
Here will there by any pressure differences arise for hot water and cold water ? How to handle both the pressures at the wall mixer ? Are there any standard calculations or best practices available?
Thanks,
Thanks,
